I was changing my stock shocks yesterday and noticed that a rubber gasket/seal on my front hub was loose, and no longer pressed into the hub. This was on the side facing the tire and had roughly a 3-4 inch diameter center and the rubber was just under 1/4 wide. I looked at the other side and it was the exact same. Anyone else have the same problem? This is a 2008 F350 4x4 but I never off-road in it.
