Help--2008 6.4 issue
I am thinking it was EGR related to tell you the truth. Based upon the chain of events...or a stuck injector that cleared itself.
I think at this point i'd run a a good fuel injector cleaner through it and call it a day.
Ensure you use right stuff for 2008 ulsd compliant diesel motors. Diesel Kleen is what I would use.
I filled up and ran the Diesel Kleen. The truck is running still running perfect after about 100 miles now. I'm wondering if my short commute to work through the week is killing me. I have about a 12 mile round trip and speeds are 25-40 MPH. I do tow about 6000-10000 but only about once a month. Would I benefit from driving in tow/haul for my work commute or am I just wasting fuel?
I'm pretty sure he's tuned, just doesn't have a tuner hooked up. So, the commute shouldn't bother anything as you are not having regens or partial regens. I would suggest you should use diesel Kleen or some other fuel treatment with every fill up. As I understand it the ULSD lacks lubricity (i guess i spelled that right) and the DK makes up for that and also keeps everything clean. I put 16 oz in with every fillup (50 gal or so) and have since 4000 miles. I'm just under 50,000 with no problems whatsoever.
Diesel32
06-06-2012 08:43 AM
