hi guys will the stock in dash fuel gauge work on a aluiminum gas tank that has the sending unit on the top its about 3 or 4 inches across has for a ground and a positive wire lead thanks
As long as the sending unit matches the ohm output as a stock one it will read the way it should. If not it will still work just read funky like you fill the tank and it reads a 1/4
