Fuel Guage
Old Oct 23, 2016 | 06:59 PM
Harley Hill's Avatar
Harley Hill
Fuel Guage
So my fuel gauge was reading Full when it was empty and way past full when it was full. I removed the fuel tank, ended up changing the sending unit for a new one. it seemed to work just fine. so I put it in the tank, put everything back together..... Ran out of gas at just below a half tank. I really dont want to remove the tank again. So if anyone knows what else the problem might be, please let me know.
Old Oct 23, 2016 | 07:12 PM
redcreekauto's Avatar
redcreekauto
You have to adjust the sweep of most replacement sending units. A simple bend is usually all it takes. You will have to remove the tank again to adjust it.
Old Oct 23, 2016 | 07:26 PM
Harley Hill
Ok, the sweep on what? Like how the bend of the toob that sucks the fuel up is?
Old Oct 23, 2016 | 07:34 PM
redcreekauto
No the metal wire holding the float. It will have to be bent. Hold it firmly at the sending unit itself and adjust it further down. Its easier to use a tape measure and measure the depth of your tank from the flange where the sending unit mounts. I usually set them where they are 1/2 to 1 inch from the bottom. I like to have a couple gallons in reserve. Our trucks won't run on fumes.
Old Oct 23, 2016 | 09:10 PM
Harley Hill
so you think my float is touching the bottom of the tank making it read higher than it is
and I need to bend it up some?
Old Oct 23, 2016 | 10:02 PM
redcreekauto
Yes most likely that is the issue your having. Sometimes to get the correct sweep up and down the rod itself must be either shortened or lengthened.
Old Oct 23, 2016 | 10:06 PM
Harley Hill
I took my fuel tank out, took my fuel sending unit out, kept it hooked up, put it at empty and it read a quarter tank. I put it at full and it read about a quarter over full. what the heck is going on??!!
Old Oct 23, 2016 | 10:11 PM
redcreekauto
Do you have the sending unit properly grounded? They work off of resistance and good grounding is necessary.
Old Oct 23, 2016 | 10:16 PM
Harley Hill
I used a wire brush and cleaned up where it is grounded (on the frame around the fuel tank) and it seems well grounded.
Old Oct 23, 2016 | 10:28 PM
redcreekauto
Its possible that the sending unit is defective or the wrong one. Doubtful but it could be your gauge as well. Or the voltage regulator for your instrument cluster could also be failing. Had the gauge ever worked correctly recently before changing the sending unit? Other gauges work ok?
Old Oct 23, 2016 | 10:39 PM
Harley Hill
the fuel gauge hasnt worked right for some time now. But just before I put the new sending unit in the fuel tank I hooked it up and made sure it worked right and it did empty was empty and full was full. Um, everything on the cluster works except the engine temp. that was going to be my next project.
Old Oct 23, 2016 | 10:46 PM
redcreekauto
I'd get a new sending unit. If you just purchased that one it should be under warranty still. I have had good luck with Dorman units FYIW.
Old Oct 23, 2016 | 11:23 PM
Harley Hill
So I went out and put it at full. It read about a quarter above full. I then slowly moved it down while someone else watched the Gauge, I got it all the way too what should have been half a tank before it even started to drop on the guage and I gave it plenty of time to move down before I got to what should have been half tank.
Old Oct 23, 2016 | 11:47 PM
Harley Hill
I even put the old one on and it acts different then it originally did before I replaced it. There is just a lot of inconsistency.
Old Oct 23, 2016 | 11:51 PM
redcreekauto
I'd check the wiring to make certain there are no bare spots. Sounds like just moving the wiring harness will create some inconsistencies.
OLDBLUEF250
21
Jun 20, 2016 09:30 AM
tbolt64
Aug 26, 2013 11:11 AM
JoeVR5
Jul 18, 2010 01:07 AM
doc54
13
Jun 8, 2008 08:13 PM
Talled20
1978 - 1996 Big Bronco
Jan 22, 2004 02:57 PM
