tire rotating on camper
I've never rotated mine, but I did have the re-mounted and balanced by a tire shop. They needed some serious balance weights (or whatever they're called).
A semi-related question. Aren't "campers" the units you slide into the bed of a truck? I've always thought that is what a camper was…while the general "trailer" term covered, 5th wheels and travel trailers. Just curious...
I rotate mine just like my vehicle. When I reach 6k on my 5er tiress, I rotate them back to front.
I think your smei-related question is a whole nother thread. But....
As far as Camper, I agree that the term "camper" at one time referred to the slide in bed mount RV. I think the term camper has evolved just like other words in any language. Many people in the past think of "pop ups" as the definition of camper. I am surprised that due to policitcal correctness "campers" / "rv's" are not called "Recreational Appliances!"
I don't rotate the trailer tires, but then, they don't see enough miles to need it. We put about 5k on the fiver last year. For us, tires get replaced because of age, or road hazard, long before tread life becomes an issue. If you put a lot more miles on the trailer than we do, then rotating them might be useful.
On the other hand, why would tires wear more in one position than another? If you've got one axle or one tire wearing significantly more than the others, it is time to visit a trailer alignment shop, because something is wrong. Or possibly you need to check weights on each tire.
thanks for your views on this. I have checked other rv forums, and from past threads others have said the same thing. As far as my refering of "campers", I guess i generalized all units. Although I did specify "towable camper" witch would exclude slide in units, and i exluded motorhomes. My opinion is that if you have a unit that has a kitchen, bathroom, living/sleeping accommodations and you can take it with you. You pretty much have a camper. While they may be called "pop-up", "slide-in", "travel trailer", "fifth wheel", "recreational vehicle", or "self contained" ; they all serve the same purpose; To get out and enjoy the outdoors, some with more comfort than others. And i guess technically the people that use these are the "camper", or is is "campee?"
LOL, not sure. Ironically, I still refer to using our trailer as "going camping". My non-RV'ing friends think "camping" is bringing a tent and sleeping on the ground, so I get funny looks when I say "we're going camping this weekend". I just think saying "going RV'ing" makes it sound like we're retired and taking a 4 month trip in a diesel pusher.
Typical camper (motorhomes, trailer etc.) yearly mileage average is something like 5-7k miles a year....
I would NEVER bother rotating tires on a seasonal used vehicle.
The tires will age, dry and crack before the thread wears down enough to replace 'em anyways.
I put about 8-10k a summer on my '87 Class C motorhome, and never rotated the tires.
Tire life is often discussed (debated). The RV manufacturers( RVIA) says 5-7 years and that figure has been quoted in multiple RV publications for many years. However, how tires are maintained and stored probably plays a greater role in life expectancy than age for most end users. IMHO.
RVIA also says, any time a tire is run at less than 85% of the pressure required to carry a rated load, it should be removed from the rim and inspected on the inside of the tire. I sure don't see that being done very often.
Steve
Steve
QuercusLobata
11-04-2017 09:01 PM
Hammer40330
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
04-22-2016 11:48 PM
Cobra93svt
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
15
06-14-2008 01:30 AM
