Rear cab mount install
when I did mine,
I installed the rubber bumper
I installed the lower arm end and bolt
I lifted the cab and forced the upper end of the arm in the mount
I had to use a tool here to get the arm hole and mount hole aligned for next step
inserted the upper bolt.
I could not get the lower end of the arm in with the rubber bumper in place if I started on the cab side.
Sam
Sam
BobCo posted this on facebook as to how he did it.
I'm not sure what his username is on here.
Just how do you put rear cab mounts together? | Facebook
when I did mine,
Sam
Sam
On my 52 I used a pry bar, a block of wood, and a six pack of beer to reward my friends who stopped by to help me lift the cab in place. Basically, I lubed the rubber parts with silicone grease (Dow Corning DC4), put the rubber bumper into the lower bracket, and installed the swing arm with the lower bolt only. I then pivoted the arm into place...but it hits the bumper before the hole for the top bolt lines up...so a modicum of force is needed (also had my friends lift the cab a little in that corner). With a pry bar against a block of wood, it only took a little force to make the upper hole line up. Then repeat the process for the other side.
I should note that I put 1 inch thick blocks of wood on the frame to support the cab until I had the swing arms attached.
Dan
Dan
Sounds simple enough. I understand the bushing has to be in first. Did you lubricate the bushing with soap or some thing? When you forced the upper end. Can you be a little more specific? Did you use your foot? I was thinking of using a rachet strap or maybe a come-a-long to bring the two arms up to align with the top portion. Just fooling around with them. I couldn't push it up far enough by hand. Don't get me wrong. I apprciate your advice, but I really need to understand how this is going to work. Or is this something I'll see when I actually start doing it. I'll be using my cherry picker and a 4x4 through the door opening to lift it. thanks again for replling to me post.
and then on the other side, a little lift and it slides right in.. both by hand..
but you have to lift the cab a little.. there is a lower lip on the body side you have to get past.
As Dan said, a floor jack and small block of 2x4 is all u need.. 3-4 inches of lift
Sam
we missed that little detail..
Sam
I like your mode of operandi, I quess it depends on brute arm muscle strength?...... and a reward....lol.....I'm gearing myself up for this operation here too shortly.
53pickemuptruck
11-20-2008 10:46 AM
Aussie 53
05-03-2008 08:56 PM
