Rear Cab mount Question?
Old May 1, 2008 | 06:30 AM
Aussie 53's Avatar
Aussie 53
As anybody have a illustration on the rear cab mount for 53-56. Just checking to see if I have the bracket in the right place. Aussie 53 Cheers
Old May 1, 2008 | 08:21 AM
53OlderThanMe's Avatar
53OlderThanMe
Is this what you need?
Old May 1, 2008 | 04:38 PM
Aussie 53's Avatar
Aussie 53
Thanks 53olderthanme, that is what I was looking for. Cheers
Old May 3, 2008 | 07:26 AM
sdetweil's Avatar
sdetweil
Anyone does this recently?
What is the trick to the rubber bumper, BAAA-5360 on the top of the rear arm, and getting the upper bolt back in? I know you are supposed to install the upper bolt last.. but with the rubber bumper compression pressure on the arm, how do you line up the bolt hole? (jack?)
Sam
Old May 3, 2008 | 08:18 PM
mechmagcn's Avatar
mechmagcn
Sam, when I replaced the rear mounts on my 53, I assembled the arms with the upper and lower mounts and then jacked the cab up until I could get a punch through one of the lower mount holes to line them up with the hole in the frame.
Old May 3, 2008 | 08:56 PM
sdetweil's Avatar
sdetweil
Ok, just finished this earlier today..
net is the instructions I got were wrong..
put the top bolt in first.. then put the rubber bumper in the lower cage and push the arm in and put the lower bolt in last..
SO much easier..
Sam
Aussie 53
Feb 7, 2017 06:21 AM
CA53ford
Nov 26, 2015 05:15 PM
Aussie 53
Oct 7, 2015 06:00 AM
Aussie 53
16
Mar 15, 2008 10:08 AM
ALBUQ F-1
31
Jan 6, 2008 01:06 PM
