Tryd the high idle switch mod
Ok so i took the purple/green and the blue/white put them together, turned switch, it worked. I mounted the switch tryd it, heard a couple zaps then the switch light went out.
Did I fry something or should i try and rewire it again. I pulled it all out after it did that.
Its an 06 quad cab
Its an 06 quad cab
Its an 06 quad cab
Its an 06 quad cab
The power wire in that combination has a fuse. I don't know what number it is and I'm not sure it's in the manual, so you might have to look for a blown fuse in a slot that is marked as not used. You probably blew the fuse. You probably also need to look at how you wired the switch. If it is a lighted switch and you wired in a ground, you probably got the wrong wires on the wrong terminals.
I think dchamberlain is correct, exactly what sort of switch are you using? Have you read this?
TheDieselStop.Com - www.thedieselstop.com
No. The purple/green is the BCP circuit to the PCM. You are trying to put 12V on this wire to cause elevated idle to occur.
The white/blue is the fused power wire. Your switch should have a blade for the power wire, a blade for the ground, and a blade for the load. The load might be labelled ACC for accessory, or something else, it depends on the switch.
daphill
16
07-22-2009 05:53 AM
strokersace
03-06-2008 09:59 PM
