transfer case bushings
Old 03-08-2012, 02:53 PM
66crawler's Avatar
66crawler
66crawler is offline
Hey guys, truck is a 1964 f250 4x4 with a t98 and a divorced t-case. The bushings are bad and I'd like to find out if anyone has a part number or knows where to get aftermarket bushings, I'm also going to see if I can get polyurethane ones if I can. Is solid mounting the t-case a bad idea?
Old 03-08-2012, 07:20 PM
MNTBUGGY's Avatar
MNTBUGGY
MNTBUGGY is offline
As much flex as you have going on with a 4wd I think i would try to stay with rubber or for a little more rigidity go with the polyurethane. Solid ones might start breaking parts or you might start to feel the drive train vibrations without it being isolated.
Old 03-08-2012, 07:37 PM
napass2004's Avatar
napass2004
napass2004 is offline
Jeff's bronco graveyard is where I got my poly mounts nice parts
Old 03-08-2012, 07:57 PM
bunchoftrucks's Avatar
bunchoftrucks
bunchoftrucks is offline
I took some poly spring bushungs and cut the small dia part off and shortened the steel insert for my 64. Usually free or really cheap at your local 4x4 shop. Had my in for years no problems.
Old 03-08-2012, 10:43 PM
66crawler's Avatar
66crawler
What case do I have? D24? It has both high and low range, my old 66 was only a single speed.
Old 03-09-2012, 11:47 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 66crawler
Hey guys, truck is a 1964 F250 4x4 with a T-98 and a divorced t-case. The bushings are bad and I'd like to find out if anyone has a part number.
4) B9TZ-6039-A (replaced B9TT-6039-A) .. T/C Bushing / Obsolete
Applications: 1959/65 F100 4WD / 1959/76 F250 4WD / 1977 F250 4WD before serial number Y20,001.
PARTS INTERNATIONAL in Farmers Branch TX has 6 = 888-727-0418.
KINSEL L/M in Beaumont TX has 6 = 800-816-2894.
GREEN SALES CO. in Cincinnati OH has 6 = 800-543-4959.
CARPENTER NOS OBSOLETE PARTS in Concord NC has 36 = 800-476-9653.
Transfer Case: 1961/63, 1964 F100/250 4WD before serial number 410,001: Spicer Model 300205-5 / 1964 F100/250 4WD from serial number 401,001 = Spicer Model 300205-6.
Old 03-09-2012, 01:28 PM
schoo's Avatar
schoo
schoo is offline
did you overhaul the case?
if so did you o/h the tranny
Old 03-09-2012, 02:00 PM
66crawler's Avatar
66crawler
Not yet, I gota do the trans soon though. I have a 150mi trip for Easter in April and 4th gear bearings are gone and makes a wicked vibration noise.
Old 03-09-2012, 02:04 PM
schoo's Avatar
schoo
schoo is offline
my 3rd gear is shot and the transfer case leaks bad so well be doing both
soon.
Old 03-09-2012, 05:29 PM
66crawler's Avatar
66crawler
I'm not sure if it is 4th gear now, it seems to happen over a certian speed not what gear I'm in, it would have to be a bearing on the output shaft or the transfercase but Im not sure how to be sure.
Old 03-09-2012, 11:41 PM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Get the vehical lifted off the ground. All 4 wheels off the ground. Get youself a mechanics stethascope and listen as someone runs the truck up thru the gears. If it is badly worn out you should be able to pinpoint where the noise is comming from. Make sure that when you have the truck lifted off the ground it is solidly stabilized. Do not do this just sitting on jacks. Block up the frame with 6x6s or box 4x4s. Be careful of the spinning wheels and driveshafts. This is all common sense stuff but today common sense is not very common.
Old 03-10-2012, 03:47 AM
66crawler's Avatar
66crawler
Yeah I don't have the means to lift my whole truck up I don't think, I need to find a lift to use for 5 min lol
Old 03-11-2012, 05:10 PM
66crawler's Avatar
66crawler
Well I was under the truck yesterday fighting with the headers to change the gaskets and my tcase looked kinda funny. I get a closer look and it was only hanging on by 1 side, the other side bolts fell out where the mount bolts to the frame. Got some bolts and fixed her up and guess what, no more grinding/vibration lol
1964FORDTUF
07-10-2015 08:52 AM
jjurva!
15
07-27-2013 11:41 AM
Raymond
09-20-2008 07:03 PM
Patrick_PDX
07-15-2004 11:05 PM
Burg460
05-02-2003 07:54 PM
Quick Reply: transfer case bushings
