Max tow mirror to paddle mirror swap?
Going to be trading/selling my 06 PSD for a F-150 Lariat Max Tow. The only time I'd need the max tow mirrors would be in the winter when I hook up to the snowmobile trailer. I believe there are only 3 or 4 bolts holding the mirrors on. How about the wiring, would it be a plug and play between the two different mirrors? Would both mirrors have power fold? Cost of the paddle mirror?
I had a 2010 F-150 King Ranch with the tow mirrors and hated them. I don't know how many times I hit the garage door jamb with the right mirror. Replacing the mirrors was going to be quite costly--about $800, I believe, and there was a very good chance the wiring harness would be wrong. The original tow mirrors did not power fold. I finally traded trucks, getting one with the standard mirrors.
Another aspect you may want to consider/investigate is electronic recognition from onboard computers. A coworker wanted to swap out mirrors on his Chevy pickup ... mirrors which automajically tilt down when reverse gear is selected (BTW, neat feature) ... but the dealer told him they could not reflash his computer to recognize the upgraded mirrors. The dealer told him that Chevy prohibited such reflashing because they'd rather he buy another truck versus improve the one he has.
For those who have made the upgrade...
I have a 2010 F150 SCrew with power "paddles"...
if I get the telescopic heated with puddle mirrors (and i'm assuming the turn signal as well) - is the wiring present for all that already? I've read about people doing upgrades, but having to run wires... I'm looking for a direct swap upgrade to towing mirrors, but retaining the power functionality... Not really into having a semi-functional upgrade (meaning some parts work, some parts don't).
thanks!
thanks!
thanks!
thanks!
literally just did the mirror swap on my 2012 xlt from paddles to tow mirrors. it was very simple, theres actually a video i found on you tube someone else did showing how to remove door panels. you still remove the screws but when i did mine i didn't remove the panels i just lifted them up to release the top part and then lower it back down and let it rest on the hooks that are on the bottom of the panel. 3 bolts and the wire harness was plug and play. no worries. my only question is it says the mirrors are heated both the paddles and now the tow but where is the switch for that?
