SYNC problem -- can't disable privacy mode
Old 03-02-2012, 12:23 AM
skizzo's Avatar
skizzo
skizzo is offline
When I got in my truck tonight after work, for some reason my iphone-SYNC went into privacy mode and I cannot get it back out. I have tried everything I can, spent probably 20 minutes with the manual in hand, ran through sequence after sequence in the controls, and no luck. Every call immediately jumps to "In Privacy". I don't believe I did anything to enable it in the first place, and the sequence shown in the manual does not work to back out of it.
Any suggestions? I'm thinking of disconnecting the phone entirely and re-SYNCing, but wanted to ask if I'm overlooking something first. Thanks.
Bill.
Old 03-02-2012, 05:36 AM
tseekins's Avatar
tseekins
tseekins is offline
Received 1,222 Likes on 804 Posts
Moving to 2009+ forum for better visibility of thread.
Old 03-02-2012, 08:14 AM
shotgunz's Avatar
shotgunz
shotgunz is offline
I think I remember several issues with iPhones and Privacy Mode.
Look through the Owner-to-Owner forums at syncmyride.com. Might find a solution there.
Old 03-02-2012, 09:10 AM
soundwave's Avatar
soundwave
soundwave is offline
When you're on a call with the iPhone and its connected via bluetooth to Sync, if you pull the phone away from your face where the speaker phone option button is on the screen it should now say "audio options" or something of the sort. Then if you hit it, it should give you the three options for making a call: iPhone(handset), speakerphone, and Sync. I hope that helps you.
Old 03-02-2012, 12:56 PM
Champ198's Avatar
Champ198
Champ198 is offline
you will need to delete the phone via the sync phone setting on the radio and delete the radio or "sync" from your phone, then repair.
mine did that same thing after i tried to run the sync status checker tool (which doesn't work).
Old 03-02-2012, 06:57 PM
skizzo's Avatar
skizzo
skizzo is offline
Thanks Tim.
Thank you others for the suggestions, will spend some time trying options over the weekend.
Bill.
EDIT: So I tried both looking at the iphone screen interface when on a call, and it was a normal iphone screen... nothing noting the SYNC connection, but the truck screen recognized it and showed "In Privacy." So then I disconnected the SYNC on my phone, deleted the phone from the truck SYNC, and repaired the phone. No luck, still sent straight to privacy. I'll keep working on it, but do welcome more suggestions. I would have thought deleting and repairing the phone would have been the sure-fire solution.
Old 03-03-2012, 10:26 AM
ddrumman2004's Avatar
ddrumman2004
ddrumman2004 is offline
Have you tried to reboot the Sync system? You can restore it factory defaults as well but try disconnecting the battery for 5 minutes and then reconnect it. That will reboot the system and hopefully clear out all data about the phone.
After all, we are dealing with a Microsoft product here.
Old 03-04-2012, 12:21 AM
skizzo's Avatar
skizzo
skizzo is offline
Thanks. There's a very long thread, going on four years now, on exactly this issue here:
Owner to Owner
Not surprisingly, it's a big debate between whether it's a phone or a SYNC isssue. I'm going to try a hard reboot to my iphone as the next step. You can't pop out the battery like on other phones when they have problems. Will report back.
Bill.
Old 03-04-2012, 03:42 PM
skizzo's Avatar
skizzo
skizzo is offline
Quick follow-up... before going to a full reset of the iphone, I just tried turning it off and then restarting after a minute or so. I did this while sitting in the truck with the phone still paired. When the phone powered back up, it worked fine without me touching anything on the truck side. The message on the SYNC display was back to normal and both inbound and outbound calls worked right.
Still not clear whether it's a phone or SYNC problem, but restarting the phone worked for me this time. Others on the SYNC site note that a full reset of the phone might be needed if powering down and up doesn't work.
Hope this helps, thanks for the leads.
Bill.
Old 11-21-2013, 08:03 AM
JDNott's Avatar
JDNott
JDNott is offline
Bill.
How To – Enter Privacy Mode During A Hands-Free Call | How To Use SYNC
Old 11-21-2013, 08:08 AM
JDNott's Avatar
JDNott
JDNott is offline
Had the same problem and found this quick fix, above. Good luck!
Old 05-15-2014, 10:41 AM
Richard T Palmer's Avatar
Richard T Palmer
Richard T Palmer is offline
I had the same problem with my iPhone and MyFordTouch, incoming calls would go to privacy setting turned ON and I would have to use the iPhone to talk.
I had the iPhone setting for incoming calls to answer to go to "Speaker", but having this setting caused the MyFordtouch to go to "Privacy" for all incoming calls.
To fix this on the iPhone, go to <code>Settings > General > Accessibility > Incoming Calls</code> the settings available are "Default" "Headset" and "Speaker", mine was set to "Speaker" and when I set it to "Default", all incoming calls were answered in MyFordTouch with "Privacy" turned off.
Solved my problem! May solve yours.
Old 05-18-2014, 10:20 AM
derek4343's Avatar
derek4343
derek4343 is offline
When I got in my truck tonight after work, for some reason my iphone-SYNC went into privacy mode and I cannot get it back out. I have tried everything I can, spent probably 20 minutes with the manual in hand, ran through sequence after sequence in the controls, and no luck. Every call immediately jumps to "In Privacy". I don't believe I did anything to enable it in the first place, and the sequence shown in the manual does not work to back out of it. Any suggestions? I'm thinking of disconnecting the phone entirely and re-SYNCing, but wanted to ask if I'm overlooking something first. Thanks. Bill.
Make sure your ringer is on. Not on vibrate
REDGKO
04-02-2019 01:45 PM
mcali2
16
08-15-2018 07:15 AM
HKusp
02-17-2012 05:44 PM
Tacswa3
6.7L Power Stroke Diesel
17
11-24-2010 07:58 AM
dfishrmn88
2004 - 2008 F150
12-09-2008 11:21 AM
Quick Reply: SYNC problem -- can't disable privacy mode
