The Title says it, what does this mean, and how can I fix it. The wiring on top of the alternator is in pretty bad shape. Is it only going to be a 5 minute fix because i need it to get to work tomorrow.
I didn't notice it when i was driving 60 down the high way, but when i got home I looked at the gauges and the light was flashing. I will hold around 2 thousand rpms tomorrow to see what happens
Mine would flicker at idle and slow cruising but if I reved it it would go out. It was my ground at one of my batts. not saying that will fix yours but it's something to look at
alright thanks for all the information i will check the cables on both the batteries, and the alternator before work tomorrow. Sure would suck if it was the alternator.
