If you were rebuilding a 460 what would you do?
Old 04-01-2012, 05:23 AM
00Boss's Avatar
00Boss
00Boss is offline
Edlebrock claims that thier top end stuff is all dyno matched together so you may not be seein any gains do to the fact your not runnin the heads and cams designed for that intake.
Old 04-01-2012, 05:18 PM
Blown 331's Avatar
Blown 331
Blown 331 is offline
If thats your opinion that is fine with me but I absolutely do not believe that ANY intake manufacturer would claim there intake will not produce any gains without their heads and cam. No way.
All I'm saying is that every performer intake I've ever seen has smaller ports that a stock intake. Thats all I'm saying, nothing more.
Old 04-10-2012, 04:19 PM
elgemcdlf's Avatar
elgemcdlf
elgemcdlf is offline
A few simple alterations that will considerably change the 385's attitude would be:
1. Swap out the timing set for an early ('71 or earlier) set. Double roller preferred as already stated.
2. Swap out the heads for C8VE, C9VE, or D0VE heads.
3. Swap out the intake for a C8VE, C9VE, or D0VE intake.
This will perk that 460 right up for small investment vs. gain.
Old 05-06-2012, 08:25 AM
dman2008's Avatar
dman2008
dman2008 is offline
One other item is to recurve the Dist as the factory distributor curve is lazy and you could pick some easy additional HP here and be all in at approx 3000RPM or a touch higher.
D
Old 05-06-2012, 09:25 AM
elgemcdlf's Avatar
elgemcdlf
D
Yes another inexpensive big gain move. It always amazes me how much money a person will spend to get a small gain when they could spend so much less & get great gains per dollar. Doing what i suggested along with the distributor will easily get you into the 375-400hp on tap gas with manifolds. If you can find a decent set of heads that you can just bolt on you can see a 150hp gain for the neighborhood of $300.
Old 05-06-2012, 09:26 AM
elgemcdlf's Avatar
elgemcdlf
D
Now it gets a bit more expensive but a set of 1.7 roller rockers. Once again an easy simple mod.
Old 05-06-2012, 10:13 AM
kettle-one's Avatar
kettle-one
kettle-one is offline
To the OP, go here, sign up, search and read. Everthing you wanted to know about the 429 and 460 is here. Have your realistic budget and goals in mind.
460 Ford Forum
Old 01-15-2013, 08:18 PM
RickBryan's Avatar
RickBryan
RickBryan is offline
So how much of engine performance is hinged on exhaust manifold diameter, in your opinion?
Old 01-15-2013, 10:50 PM
idt-572's Avatar
idt-572
idt-572 is offline
Headers are a big help once you start getting more air in the engine. Ditch the H piece in the intake to filter tubes, if it has them. The silencer has only one inch tubes inside. I am not sure yours has it put my 94 did.
Also the 90 up 460 efi had a straight up chain in them, not sure about the pre 90's.
A bowl blend and good valve job will help tremendously.
Old 01-19-2013, 09:39 AM
460me's Avatar
460me
460me is offline
Performer flows no better(or worse) than stock,but it does lighten the load about 40 lbs.
loveless41908
12-23-2013 11:11 AM
Cody's F100
07-04-2013 09:28 PM
glovemeister
15
12-30-2010 10:51 AM
tygerrrr
15
06-26-2009 02:19 PM
79BroncoJD
08-28-2001 11:52 PM
Quick Reply: If you were rebuilding a 460 what would you do?
