351M Oiling Problem
351M Oiling Problem
ive seen all the messages in this forum talking about 351m's and their oiling problem. im having the same problem. a few months ago, i installed a edelbrock intake and carb on my motor. before and after the installation the oil pressure was fine (aprox 40 lbs.) about 2 days later, i was riding around and noticed my stock oil pressure gauge almost as low as it would go, but the lifters weren't ticking and the motor sounded exactly like it did before. i replaced the gauge and i also replaced the oil pump. now with the truck idling hot, the oil pressure ranges from 5lbs to 0 lbs. at 2500 its about 15 lbs. have any ideas why it lost pressure so suddenly?
351M Oiling Problem
Stock gauges aren't all that accurate, espically after they get old. Could be that you had the problelm for a long time but until you started disturbing the sending unit it was reading incorrectly. If you have any kind of mileage on the 351m (even 70k) your main bearings are getting thin... Thus low oil pressure. Time to install some new ones
351M Oiling Problem
Pull your engine down and plasitgage the main and rod bearings. I never assemble an engine without performing this check.
Also check your oil galleries that extend from the pump. There is a restricted passage right at the pump mounting surface that needs to be drilled out. There may be other restrictions in the passages that will need to be cleaned out, modified, or re-drilled. Only a complete inspection will determine where a problem may be. I have a feeling that the main passages out of the pump may be the root cause of the notorius low oil pressure problems in these engines. It may explain why some engines suffer this malady and others don't, -just small manufacturing differences.
turbotim23
01-11-2016 04:49 PM
66crawler
23
03-12-2013 07:30 AM
