1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What's the largest comfortable tire size fit for my Superduty
Old 02-15-2012, 12:35 PM
Ironman20102002's Avatar
Ironman20102002
Ironman20102002 is offline
I have an 03' ext cab f350 superduty that has a v10 and leaf spring suspension stock tire size is 265/75/r16 i just want a comfortable wheel well fill w/o leveling kit or lift i know there are a ton of threads on this but i just havent found anything matching my situation or at least detailed that i have found your help and knowledge is greatly appreciated
Old 02-15-2012, 12:43 PM
Ironman20102002
theres the picture
Old 02-15-2012, 03:09 PM
AJB201's Avatar
AJB201
AJB201 is offline
you can go to a 285/75/16 on a factory rim without any rubbing. That is what I have on my 04 F250.
Old 02-15-2012, 03:58 PM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
Based on how tight the 285s are on my truck, I would not go bigger on a stock truck. You won't be able to run front tire chains with a 285, FWIW
Old 02-15-2012, 04:08 PM
Rongold's Avatar
Rongold
Rongold is offline
Tire Size
I have 285/75R-16 Cooper AT3's on my truck with stock plow suspension (X code front springs). I have no rubbing or problems. However, they do not fill the wheel wells. According to Cooper, they are 1" wider and 1" taller than the 265's. The next size up is 315/75R-16, and they are 3" taller and 2" wider than the 265's. They will probably hit the leaf springs on turns. Unfortunately, the only way to find out is to try them on. Also, anything larger than 285's will require wheels wider than the stock 7".
RON
Old 02-15-2012, 07:05 PM
KRDiesel's Avatar
KRDiesel
KRDiesel is offline
I have 295-75-16. They rub at lock. use to have 285 and they did not rub.
Old 02-15-2012, 07:51 PM
JonathanN's Avatar
JonathanN
JonathanN is offline
285's since stock rims are pretty narrow... 305's and 315's will balloon pretty good if you put them on stock rims. I had 315's on 8" wide rims (the minimum recommended width) and that was still a bit narrow. They also squirmed pretty good. Put my new 315's on 10" wide rims and now they wear even and hardly squirm at all. Pretty happy!
Old 02-15-2012, 08:34 PM
92f150I6's Avatar
92f150I6
92f150I6 is offline
I run 305 nittos in the summer on 10" wide wheels and only rub the air dam a little. My old 305's didn't rub at all. I have 285's on stock rims for winter, no rubbing at all, but don't fill up the wheel wells like the 305's.
Old 02-15-2012, 08:39 PM
dkf's Avatar
dkf
dkf is offline
For me 285/75R16s or 295/75R16s are what I would run, the 295 being the largest I would go. I currently have 285s and will keep buying them as I think they are a very good size for a stock height truck and stock wheels. My 285s are pretty aggressive but they do not rub at all.
Old 02-15-2012, 10:28 PM
Ironman20102002
Sweet cause I just want a bit bigger I'm buying Goodyear duratrac AT cause I'm not off road as much as I used to be and I have firestone dest MT but I like aggressive so an aggressive all terrain is nice look and still off road ready for me if I get a 2 am " I'm stuck" call
Old 01-28-2013, 10:33 PM
ronhestergto's Avatar
ronhestergto
ronhestergto is offline
My 1999 250 s duty, came with 35/12.5r18, that rub bad, found set of 265/70r17 custom wheels, with 1/2 tread dept. Would this be a good way to go? Will be pulling trailer with it. Also concerned with looks, as the 18, look so good, but too much offset, stick out, and rub l alot, just looking for thoughts ,I dont like the 16in wheels, they look to small, thanks
Old 01-30-2013, 06:56 AM
bthr22's Avatar
bthr22
bthr22 is offline
I'm pretty new to everything here, so what exactly do these numbers mean? I'm guessing the last number (R16) is the radius from the center of the wheel hub to the edge of the tire? Thanks!
openexcess
02-14-2011 10:05 AM
musclecars90
09-10-2010 08:33 PM
JWHendrix89
2004 - 2008 F150
02-10-2008 11:57 PM
jeffg1121
17
10-24-2006 11:49 AM
chicanofire
03-16-2004 08:47 PM
Quick Reply: What's the largest comfortable tire size fit for my Superduty
