Tail light bracket
I'm not sure which is correct but I'm sure somebody on this Forum does but this works and looks fine. Of course if you can't decide you can always do as some FTEers have done and change to the really great looking panel truck lights mounted in the fender.
Round tail lamps used 1932/54, shield type tail lamps introduced 1955, used thru 1966.
The correct bracket for 1948/54 (1932/54) is stamped: DUO-LAMP = B-13406 .. License Plate Bracket-Use with round tail lamp.
1955/66: The bracket is stamped: TL-55 = B5C-13406-A .. License Plate Bracket-Use with Shield type tail lamp.
1967 and later use a different bracket because the tail lamps are different, are squarish in appearance. Clear back up lens moulded within red tail lamp lens.
Bill if I understand you correctly the Ford parts manual says that the shields were only used 1955-66? I got mine from LMC Truck and they list them for use on '48-'54. See http://www.lmctruck.com/icatalog/fa/full.aspx?Page=99. Regardless I think that they are a good idea and they work well with the lights mounted under the tailgate bracket.
Shield taillamps were introduced in 1955 and thru 1960, the lenses (B5C-13450-D) have FORD block letters moulded into the lens.
1961: B5C-13450-D was replaced by C1TZ-13450-C .. this lens is plain, has no FORD block letters.
Therefore, shield tail lamps are NOT ORIGINAL for any truck prior to 1955.
I wouldn't trust anything LMC has printed in their catalogs, cuz this isn't the first time a scenario like this has occurred.
The 1948/56 FORD TRUCK PARTS CATALOG is available on a CD from hipoparts.com for $21.50, or you can buy a repro of the original printed catalog from Carpenter for $250.00.
Either way, you'll get the correct info, instead of this LMC crap info.
Yes Moe, that is what I meant by "flip". That still didn't give me enough room for the shields which I thought were a good idea given their location.
Schuyles
06-15-2012 07:46 AM
1951flatheaddave
02-29-2012 07:35 AM
54truck
15
02-03-2010 09:37 PM
