Unmarked Carb
Old Feb 8, 2012 | 11:20 AM
cjb40's Avatar
cjb40
Unmarked Carb
I need help identifying an old carb that I have. It has the "smooth" style air horn (typical of truck?), nozzle bars that are high in the middle, vacuum port and a spark control valve. The throttle base has the hole for the vacuum and is setup for a choke cable with a bracket attached to the lower middle section and on the other side of the base, a ball lever.
The throttle base has AA-1 marked on it, no marking in the circle and 94 on one side. Oh, the little accel spray bar has a #70 on it. Please help. Thanks.
Old Feb 8, 2012 | 04:57 PM
mtflat's Avatar
mtflat
Sounds like a typical Holley 94 - used on all these trucks in one variation or another. When the OEM carb was beyond r & r the owner could buy a generic 94 from lots of vendors and suppliers.
It's period correct unless you're doing a point by point restoration.
Old Feb 8, 2012 | 06:13 PM
cjb40's Avatar
cjb40
Unmarked carb
Doesn't the spark control valve which from reading an article, indicate it was used on later Y block engines starting in 1954? could it be a model 2110 or 2100? Sorry, I guess I don't totally understand your reply
Aty first I thought it couild be EBU or ECV. But seems like ID'ing it is a little more complicated than I thought. Are you saying in your reply, that a generic carb would be unmarked?
Old Feb 8, 2012 | 06:38 PM
4tl8ford's Avatar
4tl8ford
The 94 is the Holly identifying mark for that carb - It was used for FoMoCo products for a number of years
Old Feb 8, 2012 | 06:43 PM
4tl8ford's Avatar
4tl8ford
Technical Links to Holley 94 Technical info - THE H.A.M.B.
Old Feb 9, 2012 | 08:01 AM
1952henry's Avatar
1952henry
Yes, I believe he is. I have had a few that were unmarked as to model, but said Ford on the right side. These were replacements most likely gotten through a Ford dealer. I have also possessed some Holley-branded carbs, some marked 59 (for earlier cars/trucks), some TAGGED 8RT, some marked 2100. These were probably originally sourced through Western Auto, Sears, etc.
As stated, will work for a driver, but not for a show truck.
Old Feb 9, 2012 | 04:49 PM
cjb40's Avatar
cjb40
Unmarked Carb
In your expertiize, since this carb has the spark control valve, can it be used with a later style Y block enigne? thanks again,
Mayerstom
Apr 29, 2018 06:22 PM
F-1
Jun 12, 2016 12:10 PM
Tom C 56
Mar 25, 2011 12:21 PM
truckman87
1947 and Older Ford Trucks
Aug 28, 2005 11:45 PM
himmelberg
Oct 20, 2004 07:11 PM
