truck won't start after running
I though mine was going to be really hard to change because of the rusty hardware, but it is actually only 2 small bolts that hold the metal shield around the pump itself. had the old one off and the new one on in about 10 mins, too bad I spent a week and a half tinkering with it including removing the bed and pulling the in tank pump and messing up that sender unit, had to rig it back together
My 90' F150 302 did the exact same thing yesterday! After driviing for about 30 mins to run an errand. Turned it off and then went to start it up again and it would just turn over but would not start. I waited about 10 -15 mins and it startetd right up. I checked the iac valve today and it looked a little gummed up so, I cleaned it up put it back together and it's been fine all day. I'l try it again over the next few days. Just a suggestion. Good luck!
It won't start at all now with the rear pump. The new center pump is running great!
quiacato
03-08-2011 12:41 AM
powerstroke6ltr
07-12-2006 09:56 AM
