truck won't start after running
Old 02-08-2012, 04:35 PM
FordOwnerJoey's Avatar
FordOwnerJoey
FordOwnerJoey is offline
Originally Posted by Twinmill
I'm changing the fuel pump tomorrow
I though mine was going to be really hard to change because of the rusty hardware, but it is actually only 2 small bolts that hold the metal shield around the pump itself. had the old one off and the new one on in about 10 mins, too bad I spent a week and a half tinkering with it including removing the bed and pulling the in tank pump and messing up that sender unit, had to rig it back together
Old 02-11-2012, 10:18 AM
Twinmill's Avatar
Twinmill
Twinmill is offline
That's funny! I just changed my fuel pump on the center tank and it took about 6 hours total. Probably 3 hours just to get the tank to come out. What a pain in the butt!
Old 02-11-2012, 01:33 PM
FordOwnerJoey
well i meant the HP pump along the frame rail right under the drivers side. I did putt the bed and everything to check the intank LP pumps but they were fine. But I changed the little filter on the end of it, because it was black.
Old 02-11-2012, 07:47 PM
Dukernc's Avatar
Dukernc
Dukernc is offline
My 90' F150 302 did the exact same thing yesterday! After driviing for about 30 mins to run an errand. Turned it off and then went to start it up again and it would just turn over but would not start. I waited about 10 -15 mins and it startetd right up. I checked the iac valve today and it looked a little gummed up so, I cleaned it up put it back together and it's been fine all day. I'l try it again over the next few days. Just a suggestion. Good luck!
Old 02-11-2012, 07:55 PM
shorebird's Avatar
shorebird
shorebird is offline
Can any one say Vapor lock?
Check the routing of the fuel line.
Old 02-11-2012, 08:32 PM
Twinmill's Avatar
Twinmill
Twinmill is offline
I just changed the center tank pump and it works great! The rear tank finally died dor good. Will have to change it next. I think though, this time ill just remove the bed instead of trying to drop the tank out. Seems like it wouls be much easier
Old 02-11-2012, 08:36 PM
vacopper's Avatar
vacopper
vacopper is offline
Twinmill,
Did your truck act up only when it was warm ? Mine starts everytime great when the motor is cold, but drive it 30 miles and try to restart it in 10 minutes and it idles rough, shakes, et and cuts off.
Old 02-11-2012, 09:49 PM
Twinmill's Avatar
Twinmill
Twinmill is offline
Originally Posted by vacopper
Twinmill,
It won't start at all now with the rear pump. The new center pump is running great!
Mike1016
08-05-2018 02:28 PM
quiacato
03-08-2011 12:41 AM
bigreed91
04-05-2010 01:52 PM
50man
Electrical Systems/Wiring
01-31-2010 03:46 PM
powerstroke6ltr
07-12-2006 09:56 AM
Quick Reply: truck won't start after running
