Dip Stick Tube Leak
Jas hit on it, when you put the headers on they are thinner then the stock exhaust manifold so you probably have it going into the pan at a slight angle making the orings not seat and seal properly. I would pull it out, put new orings on it then your going to have to bend the bracket or the tube slightly so when it's bolted to the header bolts it enters the hole in the pan square.
33homerdoodle
11-01-2012 04:15 PM
tstorm
03-20-2011 11:07 AM
danwink
09-15-2006 10:28 PM
JQ
12-16-2004 06:56 PM
