I just saw this, I said it wrong, I meant to say timing chain cover that is common to most motors and that is what most people think of. Ours is timing gears behind the cover.
I was thinking at the end of this thread someone was going to say what type of anti freeze and how often to flush and if and when to add SCA. If you cant tell I am diesel antifreeze challenged.
NAPA sells test strips you can dip in your coolant over floor tank that tells you the SCA levels. I use a fleet guard coolant that is pre charges with SCA so I dont worry about it
