1988 F 350 Fuel Pump Ideas?
Old 01-03-2012, 05:40 PM
Oldsmoky92's Avatar
Oldsmoky92
Oldsmoky92 is offline
Hey i just picked up a 1988 F 350 daully 4x4 with the 460/5speed. It has been sitting for several years and all of the electric fuel pumps are dead! I was wondering if anyone has installed an after market high pressure pump? As for the lift pump i will only be using the rear which is a plastic tank and i plan on buying a whole new pump and gauge assembly so the fuel gauge will work. Thanks, Chad.
Old 01-06-2012, 08:39 AM
deeznuts822's Avatar
deeznuts822
deeznuts822 is offline
I would make sure that there is power at the pumps before replacing. There are known issues with the fuel pump relays and thier connectors.
Old 01-06-2012, 10:44 AM
Oldsmoky92's Avatar
Oldsmoky92
I am for sure getting power to the tank pump, i checked with a test light. I am not so sure about HP pump, i plan to check this weekend. I found a used HP at local junkyard for 35$ with a 90 gaurantee so i will most likely be getting it. AS for tank i plan to just go ahead a buy a whole new unit, its a little costly but i would like to have a fuel gauge with the 460! Thanks!
Old 01-06-2012, 12:09 PM
deeznuts822
If you have power to tank pump it's probably just a bad hp pump.
BKS72
03-20-2010 07:01 PM
sillly402
29
05-22-2009 09:14 AM
kennyrandolph
03-13-2009 04:24 PM
735.0Short
31
11-13-2005 10:42 PM
Quick Reply: 1988 F 350 Fuel Pump Ideas?
