Turning off the Tire Pressure Monitoring Sys
Old 07-21-2012, 12:22 PM
BroncoEx's Avatar
BroncoEx
BroncoEx is offline
Just replaced the tires and wheels on my 2005 EB Explorer. Purchased a set of Better aluminum wheels and tires on Craigslist. Problem is old ones had TPMS and new ones don't. I will put the sensors on the new wheels when the tires wear out, but don't feel like the expense until I need new tires. Is there an easy way to turn the system off so I dont get the message everytime I start the vehicle?
Thanks
Old 07-22-2012, 03:02 PM
RickMN's Avatar
RickMN
RickMN is offline
Black tape over the light. You cannot disable it. It's a safety feature.
Old 07-22-2012, 03:27 PM
85e150's Avatar
85e150
85e150 is offline
Received 1,596 Likes on 1,301 Posts
I looked at the way to disable it on my brand x truck. You have to get into the wiring harness to disable it there, I suppose it's similar on a Ford.
Since you plan to install the sensors at a future date, I'd go with the black tape option for now.
Old 07-22-2012, 03:38 PM
aquanaut20's Avatar
aquanaut20
aquanaut20 is offline
You could deflate the tires, break the bead and install the pressure monitors in your driveway, cost zero $$$$, and 15 min a wheel.... Philip
Old 07-25-2012, 07:46 AM
BroncoEx's Avatar
BroncoEx
BroncoEx is offline
Easiest way to break the bead???
Old 07-25-2012, 03:20 PM
85e150's Avatar
85e150
85e150 is offline
Easiest? Go to a tire store. You may need them rebalanced with the sensors anyway.
Otherwise, I used a piece of 2x6 and a jack to break the bead on a tire. Wasn't easy. You put it under your frame or trailer hitch and jack the vehicle up with the tire under it. Watch it for slippage.
I wouldn't do it that way again, now that I have my handy Harbor Freight tire changer with bead-breaker/wheel scratcher attachment.
Old 07-25-2012, 03:35 PM
aquanaut20's Avatar
aquanaut20
I threw away the lead weights yrs ago.
Install 4-6oz of beads (tire dependent) and never think of balancing again.... Philip
Old 07-25-2012, 05:09 PM
85e150's Avatar
85e150
85e150 is offline
Those the beads you put in the tire? Do they play well with TPMS sensors?
Old 07-25-2012, 05:24 PM
aquanaut20's Avatar
aquanaut20
I have installed beads in about 12 sets of tires with no adverse affect.. Philip
Brandon606
2017+ Super Duty
40
11-20-2017 09:30 AM
GJBain
2004 - 2008 F150
01-07-2014 12:30 PM
Mercury45
1999 to 2016 Super Duty
10-24-2012 01:07 PM
Brad777
Escape & Escape Hybrid
01-16-2007 09:56 AM
davidpa28140
10-02-2005 08:39 PM
Quick Reply: Turning off the Tire Pressure Monitoring Sys
