97 F-250 IFS twin beam w/leaf want to convert to coil
I was afraid that's what you would say. I think I will try some fabricating to get polyurethane bushings in there and see what happens. I like the twin beam in the sand and loose gravel, would be nice to find someone who has conquered this design flaw without scraping the ifs I like the f-150 parts idea just don't know if u could get a heavy enough spring in there
I'm watching for a solution too. My reading tells me that:
-The rear spring mounts of a 4x4 and the rear mount of a 2 wheel drive radius arm use the same frame holes. Which also means a 2 wheel drive radius arm is a good starting point from a design and fabrication perspective.
-The 2 wheel drive coil spring tower should attach in place of the 4x4 shock tower.
The serious challenge is how to attach a radius arm to the TTB. If someone could solve that issue relatively cheaply I believe the rest of the system would use factory items. A custom coil spring may be needed.
on
As far as the radius arm attachment goes, can't you use an F150 radius arm and bracket and just drill holes in the TTB arm? They just bolt on and the upper bolt also holds the coil spring mount on.
You could juist swap in a D44 TTB, i have read that you can use some of the D50 parts to "beef" up the D44. Also you'd then have to convert it to 8 lugs, which isnt too hard, jsut gotta find the pieces, but since you have a D50 donor, you'd prolly be good to go on most of the parts required.
Yes, the vans have the twin I-beam front. I had E-350 front springs in my 95 F-150.
I don't think converting to coils is really a good answer though. It's not going to just be a bolt in process, it's going to require custom work to get the suspension geometry right.
Why not just keep the leaf springs and put a good set of polyurethane bushings in? They will last much longer than the stock rubber ones.
I agree about susp. geometry, my worry is that because that small bushing is the only thing that allows the leaf to twist as the beam travels that I will loose a great deal of suspension travel or end up bending the shackle that the bushing is in by going to poly. They should have put the coils on the 250 stock, what were they thinking putting leafs on a single pivot IFS.
Turbo F100
09-22-2008 12:23 AM
