You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Quick question for you. I have a 64 ranchero with an i6 and 3 speed in it. The tranny is in mediocre shape, as is the clutch, but I'm not very familiar with the early ford manuals. What am I looking for, identification wise, to figure out what rebuild kit to buy?
The door tag lists transmission code as "1", but per the tag the engine should be a 170 and it's one of the 7 main 200's, so at least the engine is not original. Not sure about the tranny, but it's possible that's not original as well.
It's a 3 on the tree setup with no synchros in first, only second and third. Beyond that, I'm not sure how to figure out what I have.
you need to get the numbers off the trans case. there are a few 3 speed transmissions.
the 2 most popular are the 2.77 and the 3.03.
the 2.77 is a delicate trans, the 3.03 is the better of the 2
__________________
Tom
JOIN THE NEW JERSEY CHAPTER CLICK HERE
owner of almost too many fords.
That's what I needed, thanks! I have a sinking feeling they probably swapped in the 200 and left the 2.77 tranny, but I'll double check when I get home. They look pretty easy to tell apart just by size.
Yeah, I can tell you from driving it that there's no synchro in first, so it has to be that. Looks like the paper tranny for me
I'll do the clutch and see how bad it shifts after that. I had some troubles getting into second, but reading around it sounds like there are some tricks that make things easier.
1960/64 Falcon/Ranchero: Only 3 M/T available (I-6): Ford type 2.77 Light Duty (non syncro 1st gear) / Only A/T available (I-6 & V8): Ford-O-Matic 2 speed.
If shifting into 2nd is difficult, the 2/3 brass syncro blocker rings are worn.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
I've gotten into it deeper, and it turns out it's the later 200 from a 68/69 falcon, paired with a 2.77. I picked up a duplicate block mated to a c4 on craigslist, so I'll probably bolt that up once I get the engine running smoothly.
I'd sure like to grab that crossmember from your original trans setup! I'm tryin to put together the same config in my 60 Ranchero. Same situation. I have a later 200 cid and putting a 2.77 behind it, but that CROSSMEMBER is unique for the 1960. Cant find one to save my bass!
Thanks to anyone who can help. I'm in the Los Angeles area.
2) CODZ-6A023-A .. Transmission Bracket aka crossmember / Parts catalog * says 2 required / Obsolete / No Ford Dealer or obsolete parts vendor has any.
