Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero & 1961 - 1967 Econoline
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-25-2011, 12:08 AM
BlueOvalfan85 BlueOvalfan85 is offline
Garage is empty, add now
BlueOvalfan85 is starting off with a positive reputation.
VIN help on early Econoline 5 window pickup
Hello. I recently bought a 1961 Econoline 5 window pickup that I'm taking apart to restore. I need help decoding the VIN on it. Here it is: E10SH171672.
Also the wheel base is 090. Color is BM and the model is E103. The trans is A and the axle is 01. 3600 lbs GCWR and 74 HP @ 4000 rpms.
Thanks!
  #2 (permalink)
Old 12-25-2011, 12:22 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Also the wheel base is 090. Color is BM and the model is E103. The trans is A and the axle is 01. 3600 lbs GVWR and 74 HP @ 4000 rpms.
E10 = E100 Pickup.
S = 144 1V I-6.
H = Lorain OH Assembly Plant.
171672 = 1961, assembled May 1961.
90" Wheelbase.
BM: B = Turquoise / M = Corinthian White.
E103 = E100 Pickup, 3,600 lbs. GVWR
A = Ford 3 Speed Light Duty Manual Transmission.
01 = Ford 7 1/4" Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity.
3,600 lbs. Gross Vehicle Weight Rating.
74 net HP @ 4,000 RPM
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 12-25-2011, 01:39 AM
Thanks, NumberDummy!
Tags
1961, 5, 61, early, econoline, ford, forum, pickup, post, rear, specs, truck, trucks, vin, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
