Camshaft position sensor
Check engine light came on, checked at Autozone and found that the tester inidcated that the sensor is malfunctioning and engine is misfireing, even though it is running ok. Question is there a way to test the sensor before buying one. Replaced engine about 1000 miles ago, light came on at 300 miles, same sensor. I dont know if it just needs adjustment, i put it back on the same way it came out of the old engine. This is a 97 F150 4.2l.
thanks for any input.
cmp sensor out of adjustment (or you might say out of time) wont turn on the ck eng lamp. I have seen 2 in the last month that were 180 degrees out and the complaint was hesitation. Both of these had been driven for months after engine replacement so cmp adjustment was one of the latter things checked. Your best bet is to goahead and replace the sensor.
Medic27
10-21-2004 08:41 AM
