Expedition won't start after heater core install
Replaced the heater core on my friend's 1998 Expedition. Got it all put back together and we're 99.8 percent sure we got all electrical connections correct but now the truck won't start. Engine cranks but will not start. We're getting spark but apparently no fuel. We cranked the engine with the fuel line disconnected under the hood and no gas came out. We checked the fuel cutoff switch and it was not tripped. Is there a connection we may have missed when putting the dash back in? What else might be causeing this?
Will the theft light flash only when cranking the engine or will it flash with just the key inserted? I don't remember seeing a flashing red light but it was late and we were all pretty frustrated at that point. I guess it is possible that the fuel pump went bad but that would be a helluva coincidence.
If the fuel pump relay is good then you're stuck replacing the module. It's under the back of the truck over the rear axle. I too find it odd that it worked before you took the dash apart and it didn't work after you put it back together. Could there be another fuse that's not marked as a fuel pump fuse which could be blown?
The code is P0230 - Fuel pump primary circuit malfunction. My mechanic friend swapped out the fuel pump relay but to no avail. Also said the there is no current going to the fuel cutoff switch. Just to recap, here is what has been checked:
Fuel cutoff switch was not tripped and the connection is secure
fuel pump fuse was checked and not broken
fuel pump relay checked
anti-theft connection checked and secure
code P0230 thrown
code P0230 thrown
code P0230 thrown
code P0230 thrown
Chris74
1997-2006 Expedition & Navigator
11-16-2014 01:13 PM
smash fascism
04-24-2014 10:53 AM
noslow7.3
15
11-05-2011 09:14 PM
