truck wont start
Old Sep 5, 2011 | 07:04 PM
Ctkallday666's Avatar
Ctkallday666
truck wont start
so far ive been having alotta bad luck with my truck. its a 96 psd with 270xxx miles. i just fixed my oil leak problem which was my hpop leacking everywhere and making the truck run really bad. i replaced the oring and it ran fine. but now, the truck wont even start. it will turn over but it wont fire up. the fuel heater in the fuel bowl broke off. i wasent too concerned about it cause its about 155 degrees outside. so the truck has no fuel heater on it. is why it wont start? any advice is appreciated. thanks
Old Sep 5, 2011 | 07:09 PM
Action4478's Avatar
Action4478
If the WTS light is out you need to replace fuse 22 under the hood
Old Sep 5, 2011 | 07:14 PM
stainlessstroker95's Avatar
stainlessstroker95
The fuel heater in the bowl is connected to the #22 big fuse under the hood. You prob dont have the wait to part light either. Un plug the heater on the right side of bowl and replace fuse
Old Sep 5, 2011 | 07:16 PM
Ctkallday666
gotcha. the little fuel heater tooth broke off.. so i need to get a new one. but most likely this is my problem right? thinks for the tips.
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Question
Agree, if not, check your oil level (how old is it?), the HPOP reservoir level. Are your batteries good? and the starter is spinning as it should?. This beasts need a lot of juice to start.
Old Sep 5, 2011 | 07:18 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Yes, pretty sure it is. You can only disconnect it and forget it.
Old Sep 5, 2011 | 07:21 PM
Ctkallday666
yeah my oil level is pretty solid. just had my hpop oring replaced so it doesent leak. the starter is spinning, batteries good, and the hpop oil pressure is normal.
the senceor that the fuel heater is attached to is broken. where can i get one?
thanks
Old Sep 5, 2011 | 07:28 PM
Ctkallday666
and the wts light does come on. by the way.
Old Sep 5, 2011 | 07:42 PM
bad12jr's Avatar
bad12jr
155 degrees. And your working on your truck. Wow. No but what icp are you seeing cranking and duty cycle
Old Sep 5, 2011 | 07:49 PM
Ctkallday666
bad12 that was a typo. more like 110 degrees haha but to be honest iam not shure how to even check the injection control pressure.. if that can even be checked.. all i can say is that it turns over but it just wont fire up! and the only light that xomes on is the wait to start light for about 2 seconds and its gone.
Old Sep 5, 2011 | 07:56 PM
stainlessstroker95
thanks
The lil metal piece broke off my sensor too. Had to in to ford and get it. It was around 60 bucks just for that sensor. the heater cost bout the same too.
Old Sep 5, 2011 | 08:00 PM
stainlessstroker95
does your wait to start light always stay on for only 2 sec? Did you try unpluging the wire that goes to your sensor
Old Sep 5, 2011 | 08:13 PM
bad12jr's Avatar
bad12jr
I figured lol. Just had to point it. How do you know the hpop oil psi is good. That is what the icp sensor is reading.
Old Sep 5, 2011 | 08:20 PM
Ctkallday666
man stainless iam starting to get pretty stumped on what the problem might be.. i just unplugged the sensor cable but no go. about 5 minuets ago. just turned over but wouldnt fire.
Old Sep 5, 2011 | 08:37 PM
Ctkallday666
hmmm i dont know to much about all that.. the ford mechanic had said the hpop is making good pressure and it should run just fine... which it did until today. man this is kinda bothering me lol i think iam officially STUMPED!
