shift link
jeremy, the 92 up system is a cable from the column to the outer lever on the E4OD. Before you try adjusting it, if the problem just started, I would look at the column itself, the shifter is a hollow aluminum casting and is prone to split making the entire shifter flop around. I had a 1990 Lincoln Town Car and it did the same thing, couldn't get it in park. The adjustment is on the transmission end of the cable housing. There is a locking piece in the sleeve the cable goes through. You have to pull that most of the way out and with the shifter in park, push the cable casing far enough back to get the transmission into park.
You have to remove the column plastic trim covers which means taking out the ignition cylinder and removing the tilt lever if you have the tilt wheel. You'll need to take the bottom dash panel off and loosen the column mount bolts as far as you can without actually removing it. Once that is done you can reach most of the shift tube. If it is broken you will probably have to remove the column to replace it, but I was able to do it in the car on the Lincoln. You have to be able to get the cable inner end off the lever at the lower end and reach all four of the retaining bolts (Torx head) for the tube. If you get a new one from Ford, you'll need to change all the parts over from the bad one.
Michael J Kurtzweil
11-14-2016 12:22 PM
armstrongfordtrucks
10-04-2009 06:40 AM
wesmansr
07-20-2008 06:14 PM
