obd1 or obd2
obd1 or obd2
hey guys i just wanted to no if my truck is obd1 or obd2 so i can by a code reader i know that 96 was when ford switched to obd2 but i also heard that over 8500 didnt need obd2 so any help would be much appreciated trucks in my sig but its a 1996 f350 gvwr9000 4x4 5.8 thanks.
Easiest way to tell is look under the dash, if its OBDII the port will be in reach of person seated in the drivers seat.
Looks like this,
Redirect Notice
If it not there its OBDI look under hood up high just behind driver side hood hinge.
Will look like this,
Redirect Notice
Links are safe and work as intended, not sure why they show up as redirects?
Looks like this,
Redirect Notice
Redirect Notice
Ok, follow up question I've been wondering for a while. I have a cali truck with OBDII ('96 F350 460).
How much of the OBDII functionality exists with these early models? If I got something like a Scangauge II (Amazon.com: ScanGauge II Ultra Compact 3-in-1 Automotive Computer with Customizable Real-Time Fuel Economy Digital Gauges: Automotive), which of the various modes would work (EG, fuel consumption, tranny temp, timing, rpm, etc)?
I assume the early OBDII units are pretty primitive compared to modern cars. Anyone have experience with this?
on
I don't know first hand about this particular product but everything should work since all the data needed by one of these scan tools to generate it's various outputs is available via the OBD port on any vintage OBD-2 vehicle. I have used laptop based scan tools on older and newer OBD-2 vehicles and can see all the things this tool offers, and I even get the same type of display with a tuner connected to my OBD-1 truck.. though the connection is made directly on the computer and not via the OBD port, but I can watch any of the sensors operate in real time and the software calculates and displays fuel consumption and HP/TQ as well for example.
if you are going to go the scan gauge route,you could do this instead UltraGauge Automotive Information Center and OBDII Scan Tool pretty much does all the same stuff as scan gauge at about half the price. They are out of stock right now,but if you wanted to wait a couple weeks you could save some money. I put one in my 2005 focus and it works great.
meb9796
12-29-2009 03:38 PM
WALFORD'S 56
17
09-12-2007 12:40 PM
