I have the 302, correct firing order and im thinkin that i put the dist in wrong, i set the no 1 at tdc BUT i dont think i put it on the compression stroke, i have the motor at tdc and the rotor is pointing between the no 5 and no 1 post
Thanks so much friend!!!! Your post helped us out so much, turns out we were 180 out. So we fixed it set it to 10BTC and it fired right up!!! FTE HELPED US OUT SO MUCH!!!
