4 suppose to be 8
Old 12-05-2009, 03:22 PM
waits43105
waits43105 is offline
waits43105 is starting off with a positive reputation.
Exclamation 4 suppose to be 8
i have just rebuilt a 302 that i pulled out of a junk yard and swapped it into my truck, which is a 90 f150 302 and i am having a prob with a firing issue... can anyone tell me what to check out or do to see why i only have 1,4,6,7 firing and the rest seem to be dead. i pulled the plugs off all and seems the 2,3,5,8 arn't firing cause there is no change and dont die when there off. if anyone can tell or explain what i need to do from here would be great help. thanks
Old 12-05-2009, 03:39 PM
lew52's Avatar
lew52
lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Are you sure you have the firing order right, are the 2,3,5,8 getting spark to the plug . You need spark , fuel , & compression for the cylinder to fire, i would start there....Lew
Old 12-05-2009, 03:49 PM
waits43105
yes i checked the firing order it is a HO motor and have the wires ran right. htat was the first thing i checked. i do have spark to the sparkplugs. compression is there the only thing is to check i guess for is the operation of the injecters. maybe i dont know just seems odd that its not one bank out its staggerd around the motor. and being half of it also.
Old 12-05-2009, 03:52 PM
Conanski's Avatar
Conanski
Conanski is online now
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
The injectors on that motor are batch fired and you could have a broken wire which would disable 4 injectors, the pairs are 1,4,5,8 and 2,3,6,7.
Old 12-05-2009, 03:58 PM
waits43105
where do i start to check that out what am i looking for would it be in a haynes manual?
Old 12-05-2009, 05:26 PM
Conanski's Avatar
Conanski
Maybe.. but if not pin 58 at the EEC connector is tied to 1,4,5,8 and pin 59 is on 2,3,6,7, test for continuity with a DMM between this pin and each of the injector connectors(with the computer and all injectors disconnected) and if it is open simply patch in a new piece of wire. Be sure to disconnect the battery before doing any of this.
Old 12-05-2009, 05:40 PM
mikehawk's Avatar
mikehawk
mikehawk is offline
mikehawk is starting off with a positive reputation.
Are you sure it's an HO motor? I thought the trucks didn't get the HO until 1992 or 1994?
Old 12-05-2009, 07:17 PM
Conanski's Avatar
Conanski
The trucks didn't get a HO at all.. only mustangs. The truck motors did get a new roller cam in 1994 but that still doesn't make them a HO.
Old 12-06-2009, 07:15 AM
waits43105
positive its a HO motor the firing order for the 351 works and the firing order for the 302 doesnt so i would have to say it is. i will have to check the pins and see keep you updated
Old 12-06-2009, 07:24 AM
lew52's Avatar
lew52
lew52 is offline
The roller 302 truck motors uses the 351 firing order to , the main difference in the HO is the cam & pistons , up till 93 the HO had forged pistons , 93 & after hyper pistons ....Lew
Old 12-06-2009, 07:48 AM
lew52's Avatar
lew52
lew52 is offline
BTW make sure your distributor has a steel gear on it . The roller cams are steel...Not sure what dist you used ....
Old 12-06-2009, 09:16 AM
waits43105
it is the original distrb and it is a hydro roll cam
Old 12-06-2009, 01:17 PM
waits43105
i also replaced the wires cap and rotor when i droped the motor in
jimbo beam
11-20-2013 10:31 PM
mudrunner4ever
03-16-2011 05:32 PM
Lumpy78
08-04-2010 07:15 PM
alz
1978 - 1996 Big Bronco
11-06-2006 08:28 PM
Rescue Specialist
11-06-2003 09:00 PM
Quick Reply: 4 suppose to be 8
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
