General Automotive Discussion
DIY: Ford Keyless Remote Disassembly (Video)
Old 12-20-2011, 11:18 AM
ProStreetDriver's Avatar
ProStreetDriver
ProStreetDriver is offline
DIY: Ford Keyless Remote Disassembly - YouTube
How to disassemble a Ford keyless entry remote to replace the battery, clean, replace the buttons or case, or customize. The first 3/4 of the video contains how to pull apart the remote and the last 1/4 of the video contains detailed images of the different parts of the remote's case and internals.
Old 12-20-2011, 01:18 PM
SideWinder4.9l's Avatar
SideWinder4.9l
SideWinder4.9l is offline
Great video!
Old 12-22-2011, 09:20 AM
19704X4F250's Avatar
19704X4F250
19704X4F250 is offline
After watching the video I have some questions...How often should the batteries be replaced? Are Ford remotes programmable?
Old 12-22-2011, 10:46 AM
ProStreetDriver
Thank you for the comments
The battery will last for a while, depending on much much you use your remote though. Usually when you start noticing your remote won't work as far as it used to when you lock and unlock your doors, that's the sign that the battery is starting to go.
And as far as I know, the Ford remotes are programmable.
smashclash
1997 - 2003 F150
04-14-2016 06:30 AM
Gary Tice
Electrical Systems/Wiring
11-22-2013 02:22 PM
xc4jokestomper
11-28-2010 04:21 PM
joadmobile
04-04-2004 09:46 PM
wilsonv10
1999 to 2016 Super Duty
06-22-2001 07:41 PM
Quick Reply: DIY: Ford Keyless Remote Disassembly (Video)
