c6 to E4OD?
c6 to E4OD?
HI, i have a 1997 f350 that origionaly had a 7.5l, that enigne blew so a 1993 7.3l idi non turbo was installed with a 3 speed transmission which i am pretty sure is a c6. i do alot of highway driving and cruising at 55 mph is starting to get aggervating. has anyone done this swap before and can give me some advice?
on
You'll need a computer and harness to run the e4od. They arent cheap transmissions to rebuild or buy. Others will most likely add to that. If you dont know about the gear vendors overdrives, give that a search. Do you know what rear end gears you have? My idi with 3.55's isnt revving all that high at 55 in 4th gear, which would be the same direct drive as 3rd in your c6
E4OD's suck anyway.
They second guess you and you have to wait on 'em while they
unlock and lock back up again and then up and give you better
gas mileage than a manual transmission in the process.
Oh wait, well the E4OD doesn't suck all-the-way. ;)
http://www.panix.com/~alvinj/file12/hoist6a.jpg
Now ain't that a pretty sight?
That big ol' hunk of crap is outta there. :)
Here's another pretty sight...
http://www.panix.com/~alvinj/file12/hoist7m.jpg
You'll need a flywheel and a few other things tho. :/
Those things are listed all over FTE, just search for *ZF*.
ZF is too short for the search to accept so add the two stars. :)
Alvin in AZ
https://www.ford-trucks.com/forums/8...p-tonight.html Click on this link for some good info on a ZF5 swap. although he is swapping from an E4OD.
on
Electrically I had to do a few things, but I swapped EECs tho.
That part was easy with my wiring diagrams and other books
and will be easy for you too, with a little help. ;)
I bypassed the "safety" switch because Ford didn't seem to
think my '75 F150 needed that stuff back then, so I figured
my '91 Bronco didn't need it now either. LOL YMMV on that?
Alvin in AZ
Alvin in AZ
I've taught a lot of people and kids how to drive and to-use a clutch
too. I get a real kick out of it! :) Even from way over here I believe I
can "fix" your "problem", believe it? :) She needs someone besides
-you- to teach her, that's all. You could prob'ly teach your buddy's GF
no-sweat and have fun too but your GF? ...you can't. :/
Just the way it is.
You see, I could buy your GF a new dishwasher for her birthday and
she'd like it. ...let's see you get away with that one. ;)
Alvin in AZ
Just the way it is.
Alvin in AZ
on
too. I get a real kick out of it! Even from way over here I believe I
can "fix" your "problem", believe it? She needs someone besides
Just the way it is.
Alvin in AZ
Just the way it is.
Alvin in AZ
MUSKRATT2
19
01-25-2012 05:44 PM
90f150ext4.9
03-09-2010 04:51 PM
Raceallday
04-16-2005 01:02 PM
carpe_diem
09-18-2003 06:06 PM
Toms4point9
04-12-2003 12:52 AM
