f150 need help please
If you take the faceplate off of the dash , you might find that you need to simply plug in some connectors from the display, or replace some wires or the whole thing. My guages stopped working and i ended up having to go to a junkyard and pulling a new display and harness, and now it works..
Mine had issues where parts of the gauges worked or none worked and mine turned out to be a gauge cluster (Got a salvaged on for $50.), a 25 amp on the fuse box, and having a $35 sensor replaced in the rear end to get the speedo working again.
Not sure if that helps any but thats what I had to do for my 1992 f-150 w/ 4.9L & 5 speed.
mr78F150
06-20-2015 09:32 PM
blkempinc
02-13-2010 08:09 PM
