i have a 69 f-250 camper special and the wiring behind the dash is messed up is there any way to unplug the old harness and plug in a new used one if so where is the plug.
You mean the dash gauge cluster? If yes Pull it out and you'll see the white plug. This where it unplugs. But you better label the wires so you'll know what wire goes where.
Orich
There are plugs to connect everything up. They are not on the firewall, but are just an extension of the main harness, and are near the corners up under the dash. The main harness is behind the dash and stretches from the very left to the very right corners. Mine then has Red, Yellow, and Black rubberized connectors to extend out the front lights, horn, all gauges, and rear lights.
I recently purchased a 21 circuit, complete wiring harness, from EZ wiring. Even found lots of them on Evilbay. Nice feature, is that every wire is labeled, to where it goes, on the wire, every 5 inches. How cool is that? No guessing, no problems. I will photo/install it in my truck in June or July. I am using Marine grade butt splices, as they are filled with a waterproof jell, that seals the connection when crimped. I know that is a bit over the top, but leaks happen, and corrosion is part of a truck's life. Electrical failures often result in smoke, and when you let the smoke out, things stop working. Keep the smoke in.. Trace, identify, and label, as Rich says.. you will be ok.
Russ one day, I'll do the same with 21 circuits but, I hate Crimping the splices as that is the weakest link of those any aftermarket wiring systems.
Also never knew about the Marine grade butt splices connectors. "Cool"
But, I have install a view submersible water well pump motors splicing the new pump wires and epoxy over it splice. They never a leaked as, I'm still here to talk about it..
I cut the PVC insulation off of butt splices or terminal ends, make a mechanical crimp, backfill the splice/terminal with solder and then slide a piece of heat shrink over the connection.
The solder gives better conduction through the splice and keeps corrosion out of the wire ends.
The mechanical crimp is a secondary backup, in the event a wire gets hot enough to melt the solder, the end of the wire can't fall out of the splice, get against the chassis and start a fire.
Perfection amigo. Non insulated but splices are available, and cheaper too. Saves the insulation removal. Solder is the best way, especially, when you have the room to work. In tight spaces, I sometimes use the Marine grade, self sealing, splices, with a good crimper like the one you are using.
Another option to cover the soldered connection is to use "Double-Wall Heatshrink Tubing".
It has one wall really, but it is lined with hot-melt glue. I would shrink it with a $20 heat gun on low. It creates a permanent, firm, but not rigid, and waterproof connection. This technique supports the entire length of wire, without flex at the end of the solder.
It comes in all sizes, and a few colors. Cost is modest. I've used it extensively in complete wiring harnesses. It is also great for firming up wire-to-plug connections, giving a strain-relief function.
You're right about the non-insulated butt splices there BAJA. Also the "Double-wall" heat shrink with the adhesive is the better marine grade type to use 1972-34ton. If you use a ratcheting type of crimper and always crimp twice on each end, you'll never have a problem. By code a soldered connection still has to have a connector, either a twist type (wire nut type in house wiring) or a clamp type, used also. I get adhesive line heat shrink from the marine supply places (here near Everett,WA).
