Reduce Road Noise
Reduce Road Noise
So between the growl of my engine and the road/wind noise I get while driving, I have a hard time listing to music, much less talk to someone. What can I do to reduce the overall noise a bit? I plan on putting in material under the headliner when I build one, but where else can I put it?
Thanks
Jameson
Thanks
Jameson
For the ultimate in noise reduction, you'll need to use the following (or equivalent) products in order: Lizardskin, Dynamat, Dynaliner, and Dynapad on the floor, firewall, rear wall, roof, and doors... absolutely everywhere it can be installed.
2x with new window rubbers, felts, and door seals.
Suspension-wise: Rubber bushings, comfy shocks, and tires with highway tread.
With a proper insulation job and all new seals you don't need quiet exhaust. I "dynomated" used the stuf from JC witney the entire floor, firewall, ceiling and doors. On top of that the whole floor, fire wall, ceiling and doors I laid down 1/4" jute. The floor I covered in vinyl. All new window and door seals. Even without the windows rolled up I can carry
on a conversation and I run a mild 460 with headers and dual super 10 Flowmasters.
Over the next couple months or so i'm going to re-do the interior of my cab, starting at the top and working our way down. Under the headliner will be sound deading material, same for the doors. Under the carpet will be 3/8 felt padding and heat shielding material (the combination did wonders in our '81 class c motorhome). Then some material up the firewall as far as we can without tearing the dash apart. We hope all this will do some good
Haha thats my problem... Theres an aftermarket A/C installed... That pluse everything else (radio, brake controller) results in absolutly no room behind the dash.
Road Noise
I completely sound deadened my 72 F250. Prior to the project, I could barely carry on a conversation, now it is almost as quiet as my Cadillac (ok, not quite). Here is a video of my results: 72 F250 Ford Sound Deadener.AVI - YouTube
My project consisted of:
Applying rubberized spray-on underspray underneath the truck cab
Applied Zillamat (like Dynamat but cheaper) in the door cavity, entire floor, firewall area, rear cab wall, ceiling/headliner area.
Next applied layer of 3/8" foil backed jute backing insulation to entire floor, firewall, rear cab wall, headliner.
Next applied 1/8" mass loaded vinyl to entire floor.
Purchased custom made floor carpet from Stock Interiors.
Applied layer of jute backed insulation in the door panel and behind dash/cluster and firewall
Installed new door weather seals
I will probably do the same to my 74 F350 but this time I will do the Zillamat and probably the Dynapad/Dynaliner since it is a little easier to work with, although slightly more expensive.
[quote=74 F350 SCS;11027760]I completely sound deadened my 72 F250. Prior to the project, I could barely carry on a conversation, now it is almost as quiet as my Cadillac (ok, not quite).
That sounds great! Good work and thanks for posting the video. It would be hard to beat the sound level you have with a newer SUV, very impressive results.
