Lifter Size and Bore
I'm replacing the hyd roller lifters in my 302 and have noticed that I can get them in .874 diameter and .875 diameter. What is the stock size and what is the other size for?
You'd think this was a simple question but the searches I've done are confusing. Some places say the lifter is .875 diameter which implies that the actual bore (hole) in the block is larger.
I have also found posts that say the bore is .875 which would mean I would need the .874 lifter to get it to fit.
Thanks for your sage advice,
RP
RP
That is just a 1/1000th of an inch difference, I can't imagine that will make a difference. The manufacturers must just list them funny. Just make sure the part is for the proper application.
By the way, I've never experienced a problem with my hydraulic lifters, are you just being thorough?
It's hard to beat the factory Ford lifter unless your looking for a lifter for a little more RPM. You can get a little more RPM out of the factory one by just putting less lifter pre load in it.
thatguy71
05-28-2014 01:02 PM
thatguy71
05-27-2014 08:35 PM
John72_CS
01-23-2003 03:19 PM
flyboy2610
09-19-2002 01:21 PM
