Preferred method for determining new pushrod size?
Old May 27, 2014 | 08:02 PM
thatguy71's Avatar
thatguy71
Hello All,
Can anyone please help me out with the correct procedure to determine new pushrod size after head work has been done? I am working on a 390 FE with non-adjustable rockers. It is a fresh rebuild. This is my first go round with an FE and they are certainly are a little different. I have a comp cams adjustable push rod. The way that I have been doing my calculations is by setting each lifter that I want to measure to the valve's closed position (lifter on base circle of lobe). After that I take my adjustable push rod and set it to zero lash with the rocker taking care not to put any preload on the lifter at this point. I then loosen the rocker shaft and pull the push rod out and count the number of turns until it is closed then multiply by .050 and add it to the measurrment of the adjustable pushrod in the closed position. Am I then supposed to add to this the amount of lifter preload that i want? How can i determine how much preload i need? I am using an edelbrock performer plus 2106 cam and lifters. Thanks
Old May 27, 2014 | 08:15 PM
kevin316's Avatar
kevin316
Sounds like you are doing everything correct and I don't believe you need or want any preload. it might depend on the lifter though.
post this in the engine section and someone smarter than us will give you the correct answer.
Old May 27, 2014 | 08:35 PM
thatguy71's Avatar
thatguy71
Thank You!
thatguy71
Sep 7, 2016 06:17 PM
thatguy71
May 28, 2014 01:02 PM
canman51
Dec 22, 2011 07:10 AM
OldFordRacer
Apr 22, 2008 12:39 AM
M04
13
Nov 10, 2004 08:04 PM
