GP Wiring
GP Wiring
Guys, I have read the "read first" thread and haven't seen this in there. Here is pic of my gp relay. Like the genius that I am, I didn't take a pic of it before is took it off so I'm posting this. My question is: what is the second red wire for? The one from the GP harness makes sense. The other one is coming from underneath the GP controller. Please help
Here is what i do know
everything appears to be hooked up right.
The two big yellow wires that go to the big upper left terminal are connected to the pos post on bat.
The single small red wire connects to ignition switch.
The green wire that gets pinched between the controller and the "Z" bend thingy connects to the glow plugs.
That is the extent of what i know. others will chime in.
I've got wiring set up like this but don't have my batteries hooked up. I would like to confirm that all wires are where they should be before I supply power. Concern is about the two red wires. I thought there was supposed to be only one. Anyone with experience with this? I would appreciate your input.
'94 - Dunno. Didn't know about sca's or litmus testing until a few days ago. Again, suggestions would be appreciated. BTW, update on truck - after new gp's, new voltage regulator, new gp relay and one new battery, truck won't start unless i jump it off. Ran for 50 minutes to build up a charge on batteries but evidently it didn't take. Going to check fuses in the morning.
shanes66charger
Ford Truck Parts for Sale
04-04-2016 01:20 PM
teds74ford
12-20-2012 11:32 PM
tardster
04-30-2010 01:36 PM
