Tires rubbing after getting new rims/tires
Old 04-09-2003, 05:08 PM
cryptonik420's Avatar
cryptonik420
cryptonik420 is offline
Question Tires rubbing after getting new rims/tires
Hey all, I purchased some AR 767 15x8" rims and some GY Wrangler MT/R 35"x12.50" tires. After installing them I cannot turn the wheel lock to lock without the tires rubbing on the radius arms.
Question:
Is it safe to assume that I can put a spacer to compensate for the rubbing? I got the rims from Pep-Boys (idot! Doh!) and had them order them for my truck under the assumption that the correct backspacing was applied to the rim. Was I an idiot for not asking for a little bit more backspacing to compensate for the new/wider tires that went under my truck? I'm getting sick and tired of having the tires rub and I don't want to have one of the lugs catch on the radius arms and bend it.
What should I do?
Old 04-10-2003, 10:32 AM
cryptonik420
Anyone have a clue?
Old 04-10-2003, 12:24 PM
MustangGT221's Avatar
MustangGT221
MustangGT221 is offline
You mean it rubs on the radius arm when you turn it all the way? Mine does that too, lots of our trucks do. It's not a big deal, just don't turn the wheel all the way. Spacers are not a great idea. You're not suppose to turn it all the way to the steering stops anyway, bad for the P/S pump.
Old 04-10-2003, 02:54 PM
TallGuy_Az's Avatar
TallGuy_Az
TallGuy_Az is offline
My 35" Thornbirds have huge side lugs, they rub pretty hard if I turn too sharp, hard enough to make the front end jump. You aren't gonna bend the radius arm, if anything it would hurt the tire. I have had these tires for over a year now, and haven't hurt the lugs at all. My suggestion is just don't turn so sharp. I go on trails, offroading alot and need to turn sharp sometimes, and when I do, it is just a little rough for a second, thats all.
Good Luck!
Old 04-10-2003, 08:36 PM
77'F-150Mudder's Avatar
77'F-150Mudder
77'F-150Mudder is offline
What should I do?
Nope. You're not the idiot! The Pep Boys are! I swear that the Schuck's around here give out IQ tests and don't hire anyone who scores higher than 65. It's tough to find someone who knows anything at the big chain stores. Anyways to my point......
You don't need MORE backspacing to clear your radius arms. You need LESS! Aside from that, I wouldn't worry about bending the radius arms with the tires. You'll shred the tires first.
If you want to get rid of the rubbing, either adjust your steering stops or get different wheels. Adjusting the stops is free and easy although you will probably loose a little turing radius.
Old 04-10-2003, 09:31 PM
MustangGT221
I have some good sized lugs on the side of my mud terrains and they havn't shreaded or anything. It's not too bad, I'm picky and if it were that bad I'd fix it heh.
Old 04-10-2003, 10:22 PM
cryptonik420
Thanks guys for the reassurance. Just wasn't sure how stout those arms are.
Old 04-10-2003, 10:39 PM
MustangGT221
It's a Ford man, she's pleanty stout. I just bent mine in 1/2 in a car accident ha.
Old 04-11-2003, 12:02 AM
jbooker82's Avatar
jbooker82
jbooker82 is offline
What kind of lifts and tire sizes are u running in order for it to rub?
Do you have new longer radius arms or did your lift come with the drop radius arm brackets.
Old 04-11-2003, 08:47 AM
cryptonik420
I have no idea what came with my lift. Nor do I know what brand it is. Looks to be not one that a company would sell...more like redneck engineering. It does have the drop brackets i know that. Can I get extended radius arms put on? How expensive are just the arms if I can?
Old 04-11-2003, 04:03 PM
77'F-150Mudder
I'm not positive, but I think I saw that Skyjacker makes extended radius arms that are slightly bent for extra tire clearnce. I can't remeber the brand for sure but if remember right, they ran $500+ with brackets.
Tiptonite
04-21-2016 06:08 PM
CaptainJack_7
04-18-2016 06:34 PM
Ron94150
12-19-2015 12:32 PM
Backflip164
12-02-2014 02:45 PM
spnrgy
03-09-2005 10:03 AM
Quick Reply: Tires rubbing after getting new rims/tires
