Exhaust backpressure sensor readings
Yes, time for a new EBPS.
Wouldnt it be convenient if we had someone on the forum who has the EBPS in stock and at a great price?
In a perfect world, the seller would even had quick shipping and great customer service.
Gee that should would be somethin...
Oh wait...
Riffraff Diesel: Exhaust Back Pressure Sensor
Oh wait...
I checked today and I was way off. Engine off mine matched exactly. Running down the road EBP stayed around around 2 psi higher than MAP. Boost didn't make a difference in the amount change between the two, just made them both read higher. The highest I saw was 26 psi and that was 12 psi of boost.
As a Diesel Newbie, it is hard to figure out the acronyms for the various parts and it seems that it is assumed where these things are located on the truck.
Is there a book or web site that will help?
Please help me out here...
I have a 2003 F250 with the 7.3 engine and the P0470 code. Where is the Exhaust Back Pressure Sensor (EBPS) located? Also so where is the 'tube' that is associated with this that should be checked and cleaned. Pictures, etc.. would help a lot!!!
Thanks!!!!!
Thanks!!!!!
The EBPS(Exhaust Back Pressure Sensor) is located at the front of the engine just above the thermostat housing. Sometimes it can be cleaned due to a build up of soot since it receives pressure from the passenger's side exhaust manifold.
http://www.guzzle7pt3.com/ebps.php
Common Acronyms
Here is a decent thread on common failure prevention stuff. Failure Prevention Thread
Common Acronyms
runthatjunk
11-16-2012 09:10 PM
