Radio problems
Radio problems
I have a 6.9 diesel, with a new radio, it sounds great at idle or when the truck is off with the key clicked on. But when you step on the gas it turns off, than comes back on???? I rewired it straight to the battery, got a new voltage regulator. I am now out if ideas other than rewiring the hot on ignition wire. Could that be the problem? Thanks
I would also check the connector in the back of the radio. Sounds like a loose wire to me. How is it over bumps or uneven road? I ask cause mine did that for a while then slowly started actually dropping power and stalling. Finally found it when shed died cause when I signaled left she lost all power stalled and I had to tow her home.
No the voltage regulator will only allow the alternater to put out enough power to keel tbe batteries charged regardless of the alt rating. How r the grounds to the motor from the battery? Having a good ground to the radio from the motor is great but wont help if the motor is getting a bad ground to start with.
Just cause they r tight does not mean they r good. Wires corrode internally, I ended up running an extra ground to the filter housing and my truck ran better and my lights stopped flickering. My stock grounds r tight and making good connections but the wires r old and corroding and u can never have too much or too good a ground, so another ground wire wont hurt anything and yes try grounding the radio to the body
Rusty_S
06-27-2014 10:23 PM
berry1234
13
07-24-2009 04:24 PM
rmalottwtes30
12-09-2007 06:50 PM
