My brother who had my truck installed the current radio with just the positive and negative wires connected and I have to turn the radio off every time I get out. Where do I connect the yellow accessory wire? Does it matter? Thanks.
The yellow wire needs to be a constant 12v source so the clock and presets stay set. The red wire needs to be on a 12v source thats only hot with the key in the on and accessary position.
Ah, I had it backwards. Thanks. Where is the best place to connect the red wire?
If your original harness hasn't been hacked, you should have a green 2-connector pigtail behind the dash that served as the original radio power connector. One wire is blue with a red stripe, this is your dash illumination. The other is yellow. I'm not sure of the stripe color; I think it's red (could be wrong). That wire is hot-in-accessory which is what you want to use.
I know this sounds backwards - yellow wire of the aftermarket radio to constant power, then red wire of the aftermarket radio to the yellow wire of the truck, but it's just how the convention came out.
Ok, put in the newer radio last night. Got it so it turns off with the truck going off. fmc400, thanks, I tapped into the OEM pigtail for the accessory power. My question is my bro pulled the constant power from the back of the cigarette lighter. Is this a problem on for my radio? Should I wire the hot directly to the battery? Thanks.
If you never use the actual heating element part of the cigarette lighter, then it's definitely not a problem. That's how I've wired mine. I just use the lighter plug for plugging in a cell phone charger, GPS, etc. Those things don't draw much current.
If you do use the actual heating element to light cigarettes, then it's possible that if you have it heating up at the same time the radio is very loud, the fuse could blow. Or, the voltage seen at the radio power terminal could drop and the radio might shut off. Both of these scenarios are due to the fact that the heating element in the cigarette lighter draws a ridiculous amount of current. Some of the universal ones draw so much that they'll pop the factory rated fuse.
He shouldn't have a problem. As the Cigar lighter is plugged into the courtesy lamp circut on these old trucks, and so was the AM Digital display radio memory. Glove box lamp, vanity mirror lamps, etc...
Lt. Green/Yellow stripe wire. What that pigtail was for behind the dash, that you mentioned, BTW.
The constant power for the radio should only be used when the radio is off, anyway. For keep alive memory.
The Power for the amps should come from the switched source.
No its the other way around. The constant hot is where the radio will draw its power from and let the microprocessor draw a few Mill Amps of power to keep the presets. The switched 12v simply turns the relay inside the radio to on. Notice how the constant hot wire is 14ga and the switched is 18ga wire on most aftermarket radios.
Thanks. I have installed aftermarket amps and head units years ago and I always pulled off the battery. Ran a heavy gauge wire from the bat to a distribution block, then to the amp and HU. This head unit I installed is an older shaft style cassette deck and only puts out 8wx2. I didn't know how many amps the head unit could draw.
Learn something new. It's the exact opposite with factory systems, by the way.
