Brake Pedal shimmy
Old 10-19-2011, 10:58 AM
2track's Avatar
2track
2track is offline
Brake Pedal shimmy
08 XLT 4x4 Had a rotor slid freeze up last fall and eat a rotor. 39000 miles. Took apart and cleaned up and lubed, new pads and rotors both fronts. Now have pulsating pedal at 48000. Do you think the rear might need attention now or still the front? I never use the E brake.
Old 10-19-2011, 11:32 AM
Coskid's Avatar
Coskid
Coskid is offline
Well usually at about 50k the brakes are ready to be worked on so that is where I would start. I also recommend using the e-brake once in a while just so it doesn't freeze up on you.
Old 10-19-2011, 08:29 PM
air1jpg's Avatar
air1jpg
air1jpg is offline
Replace your rear rotors. I had my front rotors and pads replaced and still felt the pulsating pedal. I replaced the rear rotors and pads and all was good.
fordmustangfan67
1999 to 2016 Super Duty
08-03-2015 08:54 PM
mfp4073
1983 - 2012 Ranger & B-Series
11-27-2008 08:37 PM
umtigers
10-11-2005 05:01 AM
miked79928
03-22-2005 03:33 AM
jimbo81587
10-09-2003 05:17 PM
Quick Reply: Brake Pedal shimmy
