02 Vibrating When Braking
Old Feb 28, 2005 | 10:29 PM
miked79928's Avatar
miked79928
My wifes 02 Explorer XLT vibrates when you depress the brake pedal. It seems to do this more when braking from a higher speed. What could this be? I am a little hesitant to start tearing into this thing.
Old Feb 28, 2005 | 10:49 PM
Steina's Avatar
Steina
CO River Rat
Most likely caused by warped rotors; does the brake pedal pulsate? Have you had to replace the brake pads or are they original?
Steve
Old Feb 28, 2005 | 10:52 PM
miked79928's Avatar
miked79928
It doesnt seem to pulsate. I have not changed the pads yet. Could this be caused by worn pads?
Old Feb 28, 2005 | 10:57 PM
Steina's Avatar
Steina
CO River Rat
Could be - how many miles you got on 'er? Warped rotors are out if the pedal doesn't pulsate.
Steve
Old Mar 1, 2005 | 10:46 AM
miked79928's Avatar
miked79928
It has about 70000 on it. I guess I will need to check those pads this weekend.
Old Mar 1, 2005 | 11:02 AM
Steina's Avatar
Steina
CO River Rat
I'd say you're due, especially in the front.
Steve
Old Mar 1, 2005 | 01:36 PM
1081's Avatar
1081
Pads are fine but either turn the rotors or replace them. I have had that problem before and re-surfacing the rotors fixed it.
Old Mar 1, 2005 | 05:26 PM
nhfire 77's Avatar
nhfire 77
rotors 100%
Old Mar 2, 2005 | 09:53 PM
miked79928's Avatar
miked79928
Thanks guys. I will tackle this this weekend
Old Mar 3, 2005 | 10:58 AM
Gil Chesterton's Avatar
Gil Chesterton
I'm with the fellas. Rotors for sure. Pads are cheap as is turning the rotors.
When you do the job be sure to torque the lugs down to the correct secifications (re-check after 25-50 miles). Over-torqued lugs can lead to warped rotors. Have you ever seen (some) of those garage dudes with the impact guns putting your tires back on? Yikes!
Old Mar 21, 2005 | 11:51 PM
miked79928's Avatar
miked79928
Can these rotors be turned or are they the "disposable type"?
Old Mar 22, 2005 | 03:33 AM
marragtop's Avatar
marragtop
Most rotors can be turned at least once. As other posters mentioned, the key is to not overtorgue the wheels. I've been burned so many times, whenever I have tires installed, I retorgue each lug in the parking lot before I drive it home.
