Airbag light flashing.....
My 95 F-150's airbag light is flashing in a sequence that Im guessing is a code. It flashes 5 times, pauses for a second and then flashes one more time...then starts over and does this the entire time the truck is on. Anyone else have this problem before or know what it means? Thanks in advance!
Code 51. I posted on here somewhere what all the codes meant. Ill try and find it.
12 Low Battery voltage
13 Air Bag Circuit Shorted to Ground
14 Front Air Bag Sensor and Bracket Circuit Shorted to Ground
21 Rear Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
22 Rear Air Bag Sensor and Bracket Output Circuit Shorted to Battery Voltage
23 Rear Air Bag Sensor and Bracket Circuit Input Feed/Return Circuit Open
24 Rear Air Bag Sensor and Bracket Output Feed/Return Circuit Open
32 Driver Side Air Bag Circuit High Resistance or Open
34 Driver Side Air Bag Circuit Low Resistance or Shorted
41 RH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
42 LH Front Air Bag Sensor and Bracket Feed/Return Circuit Open
44 RH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
45 LH Front Air Bag Sensor and Bracket Not Mounted to Vehicle Properly
51 Air Bag Diagnostic Monitor Internal Thermal Fuse - Fuse Blown Due to Intermittent Short to Ground
52 Backup Power Supply - Voltage Boost Fault
53 Front Air Bag Sensor and Bracket Circuits Resistance to Ground or Air Bag Diagnostic Monitor Fault
- Rapid Continuous Flashing of Air Bag Indicator (No Fault Code) All Primary Air Bag Sensors Disconnected
- No Air Bag Indicator - Inoperative Indicator Circuit or No Battery Positive Voltage to Air Bag Diagnostic Monitor
- Continuous Air Bag Indicator - Air Bag Diagnostic Monitor Disconnected or Inoperative
[quote=86F150302;10887164]Code 51. I posted on here somewhere what all the codes meant. Ill try and find it.
That makes sence since recently my battery light will come on and the volts drop lower than the "n" in normal on the gauge. But...It will go off after a while and the needle goes near the center of the gauge.
Where do I find this fuse and the ground for it?
Thanks Again!
Thanks Again!
Its a thermal fuse with a part number ending in 167c. They are used in appliances. You should be able to find it on google. Make sure you fix all shorts in the circuit first, if not it will blow the fuse as soon as you hook the battery back up (unhook the battery for at least an hour before working on it). In the truck the fuse is inside the airbag controle module.
Determine what circuit is shorted. Look at a schematic to see what is on that fused circuit. Follow the wires to see if there is damage. Is is safe to assume you have an air bag issue since you brought up a nine year old thread?
The following users liked this post:
Mine is flashing 32 which is drivers side high resistance or open circuit... any ideas on how to fix that?
Jamespappleton
03-01-2017 07:45 AM
im2tall33
05-05-2013 09:21 AM
underDAWG
22
06-24-2006 10:46 PM
