Clutch problems
Wesley,
The fluid has to be going somewhere.
If it's not leaking out the back of the master cylinder into the cab then it must be leaking from the slave.
Right???
Is there an inspection cover at the bottom/front of your bell housing?
Is it wet in there?
I don't have x-ray vision, but it isn't evaporating...
projectmudslinger,
Try refilling the master cylinder and see if you get the pedal back.
You could be like Wesley and just keep buying quarts of brake fluid until the clutch really gives up.
It is only addressing the symptom though, not the cause.
Right???
Is it wet in there?
projectmudslinger,
I know, I know Jim.....I just don't have the $200 to fork over for the rebuild kit, pilot shaft bearing (My tranny chatters like a **** on cold startups....Not so much after it warms up...)...And a slave cylinder....
On the SC deal...I'm opting for a Sachs brand....For the whole rebuild (It's a ZF company..) and because it has metal end pieces, instead of cheap plastic...
Then theres the shifter forks.....lol
All in all....~$350....Thats a pretty good guesstimate too....
That is a-
Sachs brand Clutch, pressure plate, throwout bearing, and alignment tool...A Sachs brand Slave cylinder....The shifter forks are from our own Partsguyed.com.....
And I've already changed the fluid...Only has about 6k miles on it...
1979BEAST
12-18-2011 12:40 PM
