How to tell if shocks are bad?...
Old 09-30-2011, 08:02 PM
Doug913's Avatar
Doug913
Doug913 is offline
Repeat ? from anther thread....please excuse....
With all the chat about bad rancho shocks, I removed the lower bolt on a rear shock. The shock was slow to extend, say 20seconds to finish extending. I was able to push the shock back up to were I could hold it in place with a thumb on one hand so I could re install the bolt with the other hand. Sooooo, what constitute a bad shock? The truck has ~7500miles on it.
Also those mounting bolts they use suck. On one side a 11/32 would fit. Then rotate it to line up with another set of flats on the hex and it wouldn't fit. I ended up using a 18mm & 15mm wrench. No big deal but yikes....
So bad shocks? (rancho of course)
Amelio
6.7L Power Stroke Diesel
47
02-04-2018 10:14 PM
kconrad
11-12-2012 03:14 PM
ChristopherN
07-03-2011 08:04 PM
FireTail-AR
01-07-2007 07:10 AM
JFR3
05-12-2003 09:51 AM
Quick Reply: How to tell if shocks are bad?...
